Calendar Problem
Hooley
Calendar Problem
Hi
Got Z1  and have found that the calendar entries I have are not hi-lighted?
Anyone else have this or am I doing something wrong?
Thanks...
1 ACCEPTED SOLUTION
Rickard
Master
In Z1 the date itself is not highlighted when you have something planned. It shows if you have any meeting that day using a line (length of line depends on how long the meeting is) to the left of the date.
I agree it's hard to see if you only have a short meeting that day as it will only appear as a small dot. I will forward this as feedback.
22 REPLIES 22
Uliwooly
Does the same happen with Google Calendar?
Also, Calendar > settings > My calendars
Hooley
Yeah it's the same no matter which one is selected...
Uliwooly
how about this
settings > apps > all > calendar > clear everything > restart  your phone
mickvw
think that need to start again with calendar
😞 better on my old phone s60
need one that give me a small brake down on next apointment on home sreen with out taking up full screen
takes to much time to input apointments
Uliwooly
Why don't you enter the appointments on your computer (Google Calendar) and then sync them to your Z1?
Hooley
Tried all suggestions and the calendar entries are there but only when you select the day...On my Xperia T there would be a marker on the day if I had an event on that specific day so at a glance I could see what was up coming
Does that make sense?
Uliwooly
It makes sense, how about with a calendar widget?
Hooley
That gives me whats coming up not not as good as the at a glance that was on the T
Thanks for your ideas and advice
Maybe its something that will be addressed in an update
Uliwooly
Which build number do you currently have?
