After last software updae i cant connect to PC via usb cable. Anyone got same problem? What should i do? I ve tried all usb cables in my house, when connecting to PC - phone plays connection sound - but there to popup to choose what to do (charge, mtp, midi), also my Xperia Companion doesnt see the phone.
just fixed it.
you need to turn off the device and connect it to pc via cable, pc will install some additional drivers, after that you can turn on the phone and Charge/MTP/MIDI selection will be available!
Bro than you very much. It workssssss^~~~~!!
glad it helps
