When did Sony change their statement on using Xperia pruducts under water? They used to say up to 1.5m in depth for a few minutes, now it clearly states do not use under water.
Also noticed this is now the advice for previous products that used to say it was OK to use under water, not just the latest Z5.
Sony products are no longer water proof (what I thought anyway). Watch out!
@triboy wrote:Hi There Xperia Help people,
Instead of a "Copy & Paste" quote from your current instructions, can you tell me how you can give something a rating of IP68 and then stae the device should not be submerged. And, as for saying not to "use" it underwater, can you explain this marketing material clearly playing off this as a key feature.
https://www.youtube.com/watch?v=x09iroEd63Y
So not only are you saying it's ok to use underwater, but you're actively selling the phone on that basis. So on that basis, mine is not working following your previously specified usage. So i'm assuming it'll be no problem getting a replacement? Care to explain your way out of that one?
The reason noralmb copied & pasted those instructions is because tthey are for the specific model.....your video clip is for a Z1......specifications regarding IP Ratings have changed since that model
I was going to post in this thread because I liked the title... then I read I already did post in here ages ago. Oh how I've missed this topic. ❤️
I suggest SONY MOBILE and take down the word of "IP65/IP68",I sent my phone repair 3 time but still got problem and delay my warranty, sony mobile support on malaysia really useless can't help anything,my warranty is 4 December,pls followup my case!!and i won't use SONY any more!!thanks
Forealz? Maybe the quality control was just iffy, because I've used it under heavy water flow several times for minutes at a time, I've had non waterproof phones fall in water and be completely fine before as well maybe I'm just lucky but I think this might be a quality control issue and some phones just arne't waterproof while some off the line were as advertised
I took a photo under water. Just wanted to brag about it. That is all.
I've used the Sony Z5c underwater to take pictures in a swimming pool - treated with super oxygen tablets rather than chlorine. The photos were not that great. deleted quality. I did have problems taking photos underwater:
-The phone heated up
-The touch to take picture setting did not work underwater
-After 30 minutes the phone kept rebooting and this continued infrequently for a couple of days
Unfortunately the phone did not break, apply now have waterproof phones so I was hoping to jump ship when the phone broke, hence knowingly I used the phone. Sony stop being good phone manufacturer at the same time as Nokia. K800i being the best phone that Sony managed. With a skeleton core team and a lot of other staff, the company is not geared to greatness in this department unlike the lenses it produces.
The waterproof rating is laboratory conditions and tweaking on the same wavelength as Volkswagon and emissions, so leave the support person on here alone, at least the company owned up in a botched way to not actually being waterproof to real standards.
30 minutes with camera on, of course phone will warm up; and you used it for 30 minutes in treated water - phone isn't rated for that. It's rated for 30 minutes in untreated(clean) water.
Buy a GoPro with waterproof case if you want to take pictures in swimming pool.
And buy an "apply", I'll bet you it won't do any better.
