Microphone Problem
Green15
Microphone Problem
Hello,
i hope anybody can help me. I bought my Z5 compact last week and now i have problems with the microphone. When somebody call me, the other person cant hear me or hear me very feeble. It is like from a far distance speaking. When I turn to speaker, then the other person can hear me perfectly. I dont know what to do.
To start in Safe mode doesnt solve the problem. I dont have the possibility to turning off the microphone noise suppression.
What can I do? Who can help me?
My Android-Version is 5.1.1 .
Thanks for your help.
Green15
28 REPLIES 28
Jake-SonyXperia
Champion
Hi Green15,
Welcome to the community,
Are you using a case on the device by chance? And has this issue been apparent from the start?
lonestar1
Same here,only works if using speaker phone
Green15
Hi Jake,
I am using the official case of Sony. SCR44. This cant be the problem. Also when I use it without case, the microphone doesnt work correct.
Yes, it is from the start. But you have to know, I updated it immediately to the newest android version.
Green15
Jake-SonyXperia
Champion
You could attempt a software repair on the device. This would help rule out hardware/software.
Follow the instructions in the link below.
Software repair instructions
Make sure to backup your data with PC Companion also.
MartinJvE
I have exactly the same problem, very low volume from handset and perfect sound from speaker phone setting.
I did the safe mode startup without any improvement, I also did the software repair using the Sony Companion software, also with no improvement.
What is interesting as noted above is that the problem is only when in handset mode, speaker mode is fine.
Please help, I cant use my new phone like this and need to (unwillingly) go back to my Samsung handset
MartinJvE
all 3 comments
[–]ZoudenZ3 | MM Concept | Root + Xposed 1 point 1 month ago
You don't have to disable Google Now, just disable the "OK Google on any screen" setting. It's stupid and I wish Sony would have fixed this by now.
[–]CressCrowbits[S] 1 point 1 month ago
Any idea how to do that?
It's in the Voice settings in the Google Now app.
Qrara
Thank you for the information. Will definately try it out .
I am having the same problem! sent it for repair at Sony authorised service centre in Petaling Jaya. Technician said the phone works fine now. when I tested it, the problem is still there.
It is now lousy Sony technicians or lousy Sony products!
Waiting for them to call for a second time collection and see how it goes.
I have been loyal to Sony products since 1998, and this time the Z5 Compact is such a dissappointment. This is a basic problem
which should have not occur in the first place. MICROPHONE!
It is a BIG dissappointment because I have bought iPhone 6S and I let it go as I saw Z5 Compact which I believe in Sony so much. Lousy lousy lousy, I hate Sony mobile phones!!! Basic features.
GCC
I'm having the same issue with my Z5 compact. If I press the phone against my face then I'm heard by the person I'm calling but if I move it even an inch away from my mouth they can't here me. It's really annoying and actually getting to the point where I'm considering giving the phone back and switching to a Samsung. Sony sort it out surely this can be an easy software fix that can be put into the next update.
mikelndn
Dear sony,
its been months, and there is no fix to the issue with the microphone wiht calls only working at loundpeaker mode.
the basic phone feature is unusable.
i repaired the software, which wiped my phone, using PCC.
nothing helps,
CAN ANYONE ACTUALLY SORT THIS OUT!!!!!!!!!!
