Hello Experts,
I have NFC enabled bluetooth headset, SBH-20
But whenever I pair it with Xperia ZR (C5502), BLUETOOTH automatically gets ON and I can see 2 icons on my phone (BLUETOOTH & NFC)
My question is, If I'm communicating wirelessly via Bluetooth only then what is a use of NFC?
Why bluetooth icon gets acitvated when I pair NFC?
Kindly thow some light over this issue..
Thanks & Regards,
Anshul
Because NFC its too pair and bluetooth to transmit data, this should help you understand
http://www.androidauthority.com/what-is-nfc-270730/
...NFC has a range of around 10cm, just a few inches, Bluetooth connections can transmit data up to 10 meters or more from the source. Another drawback is that NFC is quite a bit slower than Bluetooth, transmitting data at a maximum speed of just 424 kbit/s, compared with 2.1 Mbit/s with Bluetooth 2.1 or around 1 Mbit/s with Bluetooth Low Energy...
NFC its an easy way to pair the headphones or smartwatch 2, just a tap and voila they are pair, instead of going through multiple menus, this is similar when you transfer files, its easy to pair two phones by taping them and then just transfer the files
Hi there,
Thank you for the response...
I did pair the two devices with NFC...
But the thing I am most concerned about is, why Bluetooth Icon gets appeared when I am communicating wirelessly through NFC?
Thanks a lot for solving the query.
It seemsI would have to still stick with bluetooth 3.0 or 4.0... and NFC will only work promptly with Bank transactions related tasks. As the distance between my Xperia ZR and NFC supported SBH-20 bluetooth headset; would not be lesser than 10Cms in coming future at any case..
Thanks & Regards,
Anytime
I have xperia z ultra.my problem is i have updated it to new version 14.2.A.1.136. After updating i can't pair my smart watch and sbh 52 using NFC why is that?Please help me
Hi thanx for the information but I don't know how to unchecked the throw setting and I can't see that screen shots
