Hi Rakeshroxy,
Do you by chance have any Screen dimming apps on the device? if so try disabling it and then try go through with the installation.
However this could also be regarding a damaged APK.
Let us know how you get on.
I assume that you have already activated "Unknown sources" via Settings > Security > Unknown sources. Do you know if these applications that you are going to install are compatible with Android Lollipop? If they aren't, it may be the reason why they cannot be installed.
See if the same occurs in safe mode:
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Hi Rakeshroxy,
That's great news, glad we could be of assistance
