Hi, i have a SRC24 for my Z3 but the cover didn´t change the view when closed !
It seems don´t comunicate....
Someone help me ? Thanks
When you turn on NFC, are you holding the back of the handset on the NFC sign on the cover and making sure that the handset pops up with a message that it is connected?
Hi Nuno_Soares,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I first suggest that you try downloading to download the Style Cover application from the Play Store and choose your colour. You may also want to make sure that you are connecting the devices via NFC before you put the handset in the case, if you dont do this it will not work.
Let us know how you get on.
I downloaded the "Style Cover Window B" and remove the cover. Then I actived NFC and mount the cover but nothing happen .
I only see a part of the big window but not the small window view.....
Ok, it´s working !
By the way, could you tell me when the Android 5.0 update for Z3 happens ?
Thanks
Best regards
Nuno
Any time, glad I could help. In regards to the Software update, unfortunately I am unable to supply any information regarding the release of this software at this stage.
If you watched the Sony's CES press conference, Sometime on February
Thanks.
Regards
I have tried everything mentioned here:
Installed the app
turned of NFC
No stamina
Cleared Smart Connect data
restarted handset
placed handset on the cover
turned on NFC
.....waited.....
nothing! NO popup.
The screen turns on when cover is opened, but no change in screen when closed.
What am i doing wrong?
Best regards.
