Hello I have a problem users with sony xperia z1 compact model I recently made official update to version lollipop Vodafone Romania and because this update in conversations I hear often interrupted and effectively blocked the phone is necessarily a forced shutdown .. During yesterday I was at the pool and I said I use it for the first time I entered the water in a pool very small and I tried to take some pictures all well and good until one screen closed and never opened not May not react to commands and when it comes loaded bag the red LED flashes and vibrates open meeting without even just 1 second flashing LED and vibrate .. a little advice or what would have happened with what's weird it is that it is resistant to a depth of 1 meter 30 and I even at a depth of 10 cm was not exposed and suddenly closed and not opened .. A resolution or fell to this problem. Thanks a lot a nice day!
I'm sorry to hear that, contact your local Xperia care and don't forget to request a vacuum test.
Are you saying that your phone is water damaged? if it is, contact your local Xperia care and request a vacuum test
I do not know what could be the phone book write maximum 1.30 m under water in no case I came to 1.30 m but basically has the same symptoms do not start responding to any order and when it vibrates loaded bag to assembly and flashing LED the red that and nothing more ..
