Style Cover SCR24 for Z3 crash with Lollipop
sylvZ3
Hello,
I am getting frustrated with this issue.
I have a sony experia Z3 (D6603) and style cover SCR24 which used to work fine but the cover support app now crashes 100% of time wih Lollipop.
The message I get when closing my cover with the phone on is (in french) l'application "etui-support" s'est malheureusement arrêtée. Which transltes to cover support app unfortunately crashed.
I have seen similar issues in the forum but no solutin works for me.
Can someone from Sony help find a solution?
Thanks
Sylv
1 ACCEPTED SOLUTION
remmy_byd
I left the message in other post in this forum, but.
I also had the problem with SCR24 force close. Until I loaded a non-branded firmware for my Z3 (6603).
I used to have the Orange branded version, but on the CE1 (central europe) all work fine.
So the problem is in branding.
best regareds
r
17 REPLIES 17
Phy
Legend
Legend
Try Clearing the SmartConnect app data.
How to clear data on apps.
From your Home screen
1. Tap the Application screen icon.
2. Find and tap Settings > Apps.
3. Swipe to the All tab.
4. Find and tap on the SmartConnect app.
5. Tap Force stop > Clear data.
6. Restart the phone
sylvZ3
My post has been moved to this topic but i do not agree. This topic is marked as solved when no proposed solution (and importantly the one that worked for the topic poster) work for me. I think it is fair that this post should appear in a "non solved" topic.
Ok, my topic has been reinstated, above comment is no longer useful.
The other topic on the subject is "http://talk.sonymobile.com/t5/Xperia-Z3-Z3-Dual/Lollipop-update-and-Style-Cover-Window-SCR24/td-p/95... but no solution work for me.
I have also reset data from smartconnect (although i do not understand the link between SCR24 & smartconnec) and it does not work either.
Uliwooly
Did the above suggestion worked for you?
sylvZ3
nope it did not.
Phy
Legend
Legend
Have you gone to the bluetooth, under settings and tried to manually unpair and pair the device again?
Phy
Legend
Legend
1. Settings
2. Bluetooth
3. Style cover
4. unpair
5. restart the phone
6. pair it
sylvZ3
Phy, style cover is not paired via bluetooth. It is activated by NFC (one touch).
Uliwooly
You might want to contact Sony directly
http://support.sonymobile.com/global-en/contactUs/
Phy
Legend
Legend
My mistake
