System bar
bbaydogdu
System bar
Hello guys! I rebooted my phone today. When it's opened navigation bar was missing. I tried everything i know. Restart again, factory reset, alternate nav bar apps etc. But i couldn't fix it. Nav bar still missing. Phone works still okay but without navigation bar it became so hard. Please help! Thank you Slightly_smiling_Face
1 ACCEPTED SOLUTION
Thommo
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
2 REPLIES 2
Thommo
bbaydogdu
Thank you sir Slightly_smiling_Face fixed it
