Issue 1:-
It has been 2 months now I'm using my Z3 compact.
Off lately I purchased a 32gb otg pendrive.
It gets connected to my Z3 but I can only browse data from it but I cannot transfer music/photos/videos from Internal phone memory to the OTG.
Is it not possible?? Or I am doing something wrong?
Issue 2:-
I have observed that battery life have degraded just within 2 months of purchase. It barely lasts for a day.
I have disabled most apps and just use whatsapp with limited call/sms. I dont use Stamina or ultra stamina or low battery mode.
I charge my Z3 only with its original charger. I disable roaming and mobile data at night.
I always keep my location tracking, apps update, wifi etc. etc.off.
No problems with network receptions...full bar/coverage.
So what could be the issue?
So whats the claim of Sony for 2 day battery life then???
Bootloader unlocked : Yes for those that are unlocked
Bootloader unlock allowed : Yes means can be unlocked
Bootloader unlock allowed : No means it is hard locked and can't be unlocked
Regarding issue 2, could you charge the phone full, use it as you normally do and when the battery level is low, go to Settings -> Power management -> Battery usage and take a screenshot? Also tap the items that has used most battery and take screenshots.
I tried a 3rd party tool and now I'm able to transfer my data to and fro...phone to otg.
I'm now to android so these queries.
Also I tried *#*#7378423#*#* hidden code as told by a friend &
browsed all the stuff inside and I found something which says:
Rooting Status:
Bootloader unlock allowed: Yes
What does that mean??
You may void your warranty - This depends on the nature of the fault like for example the USB port has nothing to do with an unlocked bootloader
Thanks mate.
But what status can be found on a xperia with unlocked bootloader??
Just curious to know and for some knowledge.
Is it something like
Rooting Status:
Bootloader unlock allowed: Unlocked
Ok I will try that.
But what if even thats not helping?? Shall I get my battery replaced or how?
Bad battery performance is usually caused by something running in the background using power. If you post the screenshots here we may perhaps be able to find the cause.
If it turns out to be some sort of issue with the phone or battery you can contact your local support team for assistance with having it fixed.
