xperia Z3 and Z3c Distorted Voice Calls When Connected to WIFI
itsmehuey
I purchased an Xperia Z3, love the device but experiencing a MAJOR issue with voice calls being distorted when connected to WIFI. The person on the other side of the call can hear me fine but the line on my side of the call is all distorted and garbled. If I switch off WIFI or disconnect from WIFI then the voice calls work perfectly fine. The issue only occurs when I'm connected to WiFi. There seems to be multiple reports of this issue on Whirlpool forums and mainly for Optus customers. My partner's Xperia Z3c is also having the same issue. I returned one Z3 due to this issue and was given a replacement but the issue still persists on the replacement so I think there is a software issue that needs attention and needs to be fixed ASAP!
66 REPLIES 66
mysticstryk
Same problem here except it also happens with WiFi off.
nicearms
Thanks for starting this thread #itsmehuey. I have the same issue.
I also contacted Sony's Xperia helpline who said I could send the phone off to New South Wales to have it, "repaired," if a hard reset/restore/update etc. didn't help (which it didn't, unsuprisingly). Sending the phone off for a repair, which it seems would accomplish nothing at this point, could leave me phone-less for two weeks, which is something I can't afford to have happen.
I really hope Sony can fix this issue. It's suprising how frustrating and upsetting it is - the Z3 is otherwise such a fine piece of kit and it's such a shame this is occurring.
Please resolve this issue promptly, Sony!
MrB-in-Australi
My wife's brand new Z3 has same issue - on the Z3 you cannot hear the other person talking, but from the other end, the hear the z3 fine. Z3 is distorted / clips the sound. Problem is intermittent, but occurs on about 70% of calls. Carrier is optus. Optus replaced the phone, next z3 exactly the same. Optus replaced SIM, still same problem. Have tested all GSM / WCDMA / LTE modes; and Wifi on/off in all combinations. Problem appears to be reliably reproduced when wifi connected, regardless of GSM / WCDMA / LTE, however I won't declare categorically yet that it only occurs with wifi on (more experimenting required). I have a suspicion there is a comparability issue between z3 and Optus' network equipment. Is anyone experiencing this problem on a carrier other then Optus?
itsmehuey
Hey guys just out of curiosity, what modem/router is everyone using when they encounter this issue? I had my wedding last weekend and was connected to our hotel's WIFI and was able to make and receive calls perfectly with no voice distortion or clipping. I was connected to 4G as well. But when I got home and connected to my home WIFI modern/router it started to crap out again on voice calls.
Personally I'm using a Netgear DGND3700v2. Also in Optus too.
MrNB
I'm so glad I found this thread.
I have been experiencing the same issue since receiving my Z3. Able to make/receive calls, however when connected to WiFi I'm unable to hear the caller, while they can hear me. Have tried troubleshooting using other WiFi networks. Only solution I have found is to manually switch to GSM network when connected at home.
Have just had my phone sent back to me from Optus saying "they could not replicate the error".
A solution would be great, and probably save some poor innocent phone staff from a righteous bollocking.
Dark_Xperian
Offering my two cents... I initally had issues with popping, clicks, and sometime garbled voices on my end. I ended up calling Sony Support and they informed that VoLTE (Voice over LTE) was the issue. After I disabled this, the issue was resolved.
Also, with previous phone that have has Wifi Calling enabled, I also had issues. I've disabled this as one of my inital setting changes after getting the phone.
Maybe this might work for some of you?
Thanks.
Johnathan
itsmehuey
Thanks for your reply, Jonathan. Where can I find the setting to disable VoLTE? I don't see this anywhere in the settings. Could this be a regional thing? I'm in Australia
Dark_Xperian
@itsmehuey,
It may be a regional thing. But it's under Settings > Call Settings > Enable VoLTE.
nat2319
Hi All, I am having the same issue!! When at home always connected to wifi through a net gear router and have the intemitent problem of not being able to hear people when making phone calls. After reading this forum I tried a test I made a phone call and half way through it connected to my wifi network then soon as it was connected I lost audio from the person on the phone by ear speaker, loud speaker and headphones. This is my 2nd xperia z3 after thinking my the first one was faulty and getting a swap from virgin mobile. Only today I have tried and seems like I can overcome this by having wifi off but it's too early too tell. I'll give it a few days and update this forum on what I find. I think the xperia z3 is a great phone however this issue is Extremely frustrating spend hours of my time trying to fix! I think sony should put out a statement or something of the like to stop people going through the same thing and not knowing what a earth is going on after hours on the phone and in store. It's pretty sloppy for a big company! Hopefully a fix is coming soon!!!
itsmehuey
i think it may be a regional thing. on the optus/aus firmwares there is no setting for VoLTE.. nor do the Generic Global firmwares have it. Only firmware I've seen it on that is compatible with my phone is the Singapore (D6653) and I tried it, didn't do anything.
