while updating an error (saying something like it cant connect) happened then my z2 wont power on, when i charged it led is blinking red light
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
Above are the steps that might help.
Connect the phone to a wall charger > press and hold the power key for 10 seconds > let it charge for 2 to 3 hours > repeat the update process.
Thanks ill try it ^_^
Keep us updated
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Thanks, now my z2 is good as new ^_^
Awesome.
