Z3 Compact will not connect to WIFI
skng
I have no idea why my phone won't connect to WIFI.
The problem happened overnight and I didn't dropped my phone or whatever. The home WIFI is definitely working because I am currently using it, my phone could connect to it before and other phones in the house can also connect to it.
I have tried everything to fix the problem. I have changed the advance WiFi settings - doens't work. The WiFi won't turn on and shows a status like this - FOREVER.
I bought the phone in HK in January but now I am in UK and have no access to a Sony shop. Does anyone has any clue how can I solve this?
25 REPLIES 25
kayatoast
Hi, I have tried factory resetting the phone and used PCC to try to rectify but it is still the same..
Initially, my phone was unable to receive and send text message as well, but at least that issue is resolved after performing the above action.
Used the diagnostics test and it said that it is working fine.. I fiddled around with the phone and found that if I switch on both wifi and bluetooth at the same time I can hook on to wifi fine. strange.
Christofer
Champion
@skng Sorry to hear that. In that case your phone needs to be examined by a technician at one of our authorised service centers. Please contact your Local support for information on how to proceed from here.
@kayatoast Very strange indeed. If it keeps behaving like this I suggest that you as well contact your Local support.
RLN
Hi, I have the same issue here. I have a xperia z3 compact which have been working fine since it was purchased approx 1 yeas ago. Now, for some reason, wifi will not turn on. I can pull the slider to ON or to OFF but it still seem to be searching for network for ever. I have tried to run diagnostics, which tells me nothing is wrong with wifi. I have also tried to kill running processes to see if something was hanging. Eventually I saw a post in this thread, saying that turning Bluetooth on at det same time made the wifi work. I tried this, and same thing happen for me, wifi works! But this did not last for long. After some minutes, when I was writing this post, wifi was turned off again, and now I am not able to turn it on again even when turning Bluetooth on at the same time,
At first I thouth this had something to do with Marshmallows, Android 6.0.1, but this thread seems to be posted before Marshmallows was released on Z3. I also had 6.0.1 running for a couple of months without trouble so this has to be related to something else.
I see a lot of discussions in several groups mention this problem.
Has Sony come up with a solution here?
(Please do not suggest repair through PCC....)
YoGem
Leader
@RLN, do you happen to have a 5ghz or dual band wifi router? Any Bluetooth device connected also when this happen?
JotaSe1
So... did you finally solve the problem??? I have the smae issue since January, I finally gave up...
GingerT
Is there a fix for this happening to me now for last 3 days tried restore and still not working
GingerT
Just an update Sony have said this is not covered under Warrenty even when you can go through these support pages and see lot of users having the same issue, terrible service.
joco4
Have the same problem, send it to the service.
The answer is: The repair costs 250€ !!!!
My phone is 2 years and 3 month old........
 Hi All,
I have got the same problem too: the WIFI would not start, but the Diagnostic WIFI test OK, and the WIFI MAC id has changed to 02:00:00:00:00:00 .
Is it any type of Hardware error?
VioletVivid
Heya all.
Has there been any cure for this at all?
My Z3 Compact has just stopped connecting to WiFi, and is running hot, having changed its WiFi MAC adress to 02:00:00:00:00:00 .
Thanks
