@SophiaW, @uliwooly
The 4th day without the problem - looks like I've found the way to resolve my issue.
I just uninstalled AntiVirus Security by AVG Mobile (was preinstalled) and my troubles with turning off disappeared.
Thanks all!
Repair the phone with PCC and report back
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Hi gelert, welcome to the community!
Follow @Uliwooly's suggestion & keep us updated.
Here are some additional steps on running the repair through PC Companion:
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
Running the software repair on Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
I'm sorry to hear the software repair didn't work, you might want to contact your local Sony Xperia Care team.
To save logs from PC Companion:
Note! PCC logs are saved on the user’s computer for 5 days so, meaning normally there’s no need to reproduce the issue to retrieve the logs.
