1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
@waynefatboy wrote:Anyone know why u can't assign the TV button to goto an hdmi port with the UK firmware but u can with eu firmware?
How do you do that?
This release introduces the *****ty lag in the Satellite tuning menu, which was there in v3169.
EDIT: My first freeze in the Satellite tuning menu.
you only have to tune it once, so does it really matter? Is the everyday use of the TV responsivness improved?
@psp888 wrote:you only have to tune it once, so does it really matter? Is the everyday use of the TV responsivness improved?
Yes it does because I don't want to scan a entire satellite but a few transponders and it's very painful.
The overall responsivness has definitely improved.
I am going factory reset it later and start from scratch.
At last I can post...!
Tarzion... you dont think that they have reverted back to a firmware version that is actually more stable and thus reintroduced the tuning lag you are on about?
Have you factory reset it yet?
@adyjay33 wrote:At last I can post...!
I am pretty sure Sony have tried to "fine tune" v3169 but not all parts of it.
I will factory reset later.
I've now downloaded the update twice, but when I check to see if it's finished downloading, if it has then it asks me to check if there's an update again. If I check it, it'll say there is one and start the download again! What the hell
And now I get an error message, saying the update server is temporarily unavailable. Looks like I'll have to use a usb
I used the USB and it was quicker to update that way.
I think this version for UK is the equivalent version of 3.169, made for the rest of Europe.
http://www.sony.se/support/sv/content/cnt-dwnl/prd-tvhc/bravia-kd-4Kmodels-firmware-update-v3169-eub... (swedish - use chrome thanslate )
Version 3.169 fixed pretty much all issues for me
-A/V sync issues
-Remote lag
-Black screen
-Freezes
-etc
Sure, the UI is not the most responsive in the world but in 10 days (since the update) I've not experienced any of the issues above. It now e.g. checks for a valid network connection before trying to do something that requires just that - probably something that caused some issues before.
I have only noticed some remote lag when being a bit too fast in the menus - something that resolves itself if leaving the remote "alone" for a few seconds.
Huge improvement I must say!
//Mike
