2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
ahodgekins1979
My KDL43W756 was collected today and now have a 42inch LG (42LF652V) in its place.  While the Sony has the edge on physical size/appearance, the LG is better in every other way. Better viewing angle, sound perfectly in sync, great picture (followed guidance on YouTube for calibration), fast OS, freesat.  3D is good too, and the glasses you get from the cinema work with it.  Wishing I'd bought the LG in the first place, and it's even cheaper.  Farewell Sony.
jadeee
Well fed up with this TV now been struggling with it since October - now decided enough is enough - lets try and return the flaming thing.
Holdski
My w855c is going back shortly!  Any recommendations for a replacement for roughly £1600?
Jimmyjamh
Am I literally the only person here who hasn't had any issues?
Sent from my iPhone
royabrown
Enthusiast
Sent from my iPhone
Nope.Youre the person who found he couldn't change his DNS settings.
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
Risc0n
Contributor
Sent from my iPhone
Stop trolling.
Jimmyjamh
@Risc0n wrote:
Sent from my iPhone
Stop trolling.
I'm not. Admittedly I'm only three weeks in but I've had no issues. The only time I had a problem was when I first set up youview. The tv hung for a few minutes after setting up but since then it's been a nice smooth experience.
Risc0n
Contributor
@Jimmyjamh wrote:
@Risc0n wrote:
Sent from my iPhone
Stop trolling.
Well a the fact that this thread has over 400 pages should make it clear that these issues are not isolated. Also the latest UK firmware is considerably more stable than any other iteration to date. For starters I can guarantee you will see issues with auto picture mode if selected, just search my thread. Also I can guarantee you will not get 5.1 sound from the Amazon app. Also as you are on the UK firmware you won't have usb recording nor picture in picture. So that's three issue you now have.....
Jimmyjamh
I appreciate the issues aren't isolated. I'm simply saying I've been very lucky so far. That's not to say i won't he issues. I don't class PiP and HDD rec as issues because I knew they were due to be delivered later when I bought the set. Amazon I don't use, I'm solely Netflix and all my inputs are set to use custom because I've calibrated it using a proper disc.
Sent from my iPhone
oodles2do
Anyone that's got the USB recording and PIP/PAP features, is your android version now 6.0, Marhsmallow? Or is that still to come.
