Can I just confirm that the BDV-N7200W doesn’t support Dolby Digital Plus over HDMI? (Even after software update). I find it strange that this system doesn’t with high speed HDMI cables connected to Netflix and Sky Q etc.
Thanks
David.
The HT specification report DD+ as supported:
Decoder: LPCM (2 / 5.1 / 7.1ch), Dolby Digital, Dolby Digital Plus,
Dolby Porlogic, DTS, DTS 96/24, DTS ES(matrix 6.1/discrete6.1), DSD,
Dolby True HD, DTS HD HR, DTS HD, DTS HD LBR, DTS Neo 6
How do you feed the audio stream to the to BDV? An external device connected via HDMI or a TV via HDMIARC? Could it be the device that doesn't support it?
Hi rooobb.
I connect my Sony home cinema to my tv via arc with high speed HDMI cables.
In the instruction manual there is a dash (-) through the HDMI 1 and 2 where it says Dolby True HD and Dolby Digital. That’s what makes me question it.
Thanks
David
