I’ve been having a nightmare trying to set up the AV receiver so it always defaults to playing HDMI sound out via just the AMP instead of AMP+TV. I can do this manually of course through the AMP menu, but want to find a way of saving this setting so it’s selected when turning on the amp. Any suggestions? I am using an Optima projector is that makes any difference.
Thanks so much,
Harry
Hi Harry,
Welcome to the Sony Community.
I'll look into this and will update the thread if there is a possible solution.
Best wishes,
Sean
Hi Harry9966 ,
This depends on the connected device settings I believe.
Have you tried connecting ti to a TV and selecting the audio settings to be audio system only?
Cheers,
Rose
