Android TV USB HDD Recording
40,619  Views
Live recording
2K models: Allowing you to record live broadcasting, while still enjoying content from other inputs such as Blu-ray Discs, online streaming services and Internet browsing.
4K models (equipped with Twin Tuner): Allowing you to record one channel while watching another or still enjoy content from other inputs such as Blu-ray Discs, online streaming services and Internet browsing.
Full Timer Recording
2K models: Allowing you to schedule recordings.
4K models (equipped with Twin Tuner) Allowing you to watch and schedule multiple channels simultaneously.
Event Duration Extension
Extend the time before and after the recording time of your selected programme. For example, extending the start time by 5 minutes and end time by 10 minutes for a programme between 16:00-17:00 shown on the electronic programme guide (EPG), will record from 15:55-17:10 - displayed on the Timer List.
Event Duration Extension - start and end time
Event Duration Extension - disable, 5 min or 10 min
IMPORTANT:
If two sequential programmes are set to record, and the Event Duration Extension causes an overlap, the earlier programme will have priority. For example: if the user sets the timer for a programme at 16:00-17:00 and another at 17:00-18:00, using the same timings, the first programme will be recorded between 15:55-17:10 and the second programme between 17:10-18:10.
Deleting programmes from the Timer List
The ability to delete Timer Recorded programmes from your TV. Use the following steps:
  1. Select Timer List
  2. Press the Action Menu button on the remote control
  3. Select Delete from the menu
  4. Check the timer/programme to be deleted and select Delete option
Timer List
Delete recorded programme
NOTES:
  • Programmes can be scheduled to record from the electronic programming guide (EPG)
  • The "Event Duration Extension" features extends the recording time (start/finish time) to avoid missing the recorded programme (full timer only)
  • In order to cancel the timer recording, you will need to navigate to the "Timer List"
15 Comments
E30Mark
What is the defualt HDD parental lock PIN for my android TV KDL-43W805C?
Having waited 9 months for the USB HDD recording to work, I have just recorded a couple of programs, but it asks for a PIN for me to view the recordings, I have no recolection of setting up a PIN. I've tried the usual PIN number I would have set, but nothing seems to work. How do i reset the parental lock PIN?
tarsup
Deleting programs from timer list - from where i can find that timer list in x8509.
Not applicable
To access the your recorded programs, simply go to the Action Menu, or press the 'Title List' button on the remote control.
niallmilner
If you record Freeview, can you watch satellite input whilst it's recording?
bajar01
Can I use the Sony HD-E2 External Hard Drive (Wired, USB 3.0 (3.1 Gen 1) Type-A, HDD, USB, Silver, 3.0 (3.1 Gen 1)) in order to do direct recording from my Sony BRAVIA KDL43W805C televison onto this item?
petkent44
Is "Series Record" available? ie the ability to record all the episodes of a series in one click?
matt-netley
If I plug in a USB HDD will I be able to pause, rewind live tv.
Garymjh
My tv recordings on my 55x8005c all turn out jerky or a bit stuttery. Annoyingly I can't find a single instance of anyone reporting the same thing so I'm clueless about it. It happens on usb sticks,  wd drives, my passport drives, everything. I've tried every single setting on the tv and they're all jerky and not smooth. Moving the motion setting to 4 helps a little bit with the jerkiness but at that high it then makes motion look generally odd. Motion setting isn't needed at all on live tv.  I'm hoping someone like quinnicus can give any sort of help on this but I'd welcome any comments or suggestions. Thanks very much.
Mooly01
Contributor
I am encountering the same issue as Garymjh in that test recording I have done all have a slight and subtle jerkiness to them, as if a random frame was being dropped every few 10's of milliseconds. Its very subtle but does render the recording feature useless for enjoyment of recorded material. The effect is  the same whether its an HD or SD channel.
TV is a new KD43XD8305 running the latest firmware.
Garymjh
Finally someone else has the same problem. I think I'll have to send mine in for assessment/repair as there's no way I could sell it with the micro stutters on the usb recording facility. There's no chance of Sony even addressing this issue when, as far as I know, we're the only two people who've even noticed it.
Mooly01
Contributor
I have started a new thread in the Android TV forums:
https://community.sony.co.uk/t5/android-tv/usb-recordings-are-jerky-when-played-back/td-p/2271707
I have a feeling thit problem is almost certainly a problem with the functionality of the operating system and/or firmware rather than something that can be repaired at a component level. Whether a fix or solution can be found remains to be seen.
Ringit50
What a let down Sony. Bought a new Android set but you can't record from the youview tuner. To use the hard disk recording feature you need to exit youview and retune to Freeview. Last Sony set for me.
Mooly01
Contributor
I would have thought the YouView question was down to licensing.
Does any manufacturers TV with USB record capability and that has YouView allow recording?
cherrybn
HDD recording asks for PIN i have not set a PIN
Joe_Dohn
Specialist
This might be the parental control/parental lock PIN, I believe the default is 1234.
