DVD player with scart connection
fuzzbucket
We have a Sony DVP-SR150, which is absolutely brilliant. It only has a Scart lead. We now have an HD-ready TV which has only HDMI ports available (we do also have the three socket red/yellow/white connectors on both, but that didn't work - we got sound but no picture.)
Will a simple Scart/hdmi cable make the player work properly with the TV ? If not - what will ?
11 REPLIES 11
fuzzbucket
No, Scart to composite didn't work at all, so we ordered a cheap Scart splitter cable with a switch.
https://smile.amazon.co.uk/dp/B00AXZV9UW
That worked - though we had to set all the picture settings all over again for some reason. I think the switch is probably essential, to anyone else wt this issue.
Thanks for all your help - at least I didn't spend rather a lot more to buy a converter !
IamNic
Hello @fuzzbucket,
thank you for reporting back and confirming that you got the player to work on your TV.
- Nic
