Hey people. Joined beacuase laptop dvdrw does not seem to work anymore! Not responding when I press the button, ive opened via pin, put disk in but still nothing! Looked via google for help it says to delete some files via regedit, still dead. If I was to get a new one and install, which one can I get which is cheap? Any other options?....Vaio Model is VGN-CS16G, it is an asian model.
Regards, Niv
Bump!! Any advise regarding the drive?
Hi Niv,
In theory any modern slimline DVD RW drive should fit but attaching the bezel (face plate) may take a bit of ingenuity. If you post details of the manufacturer and model number then someone may be able to provide advice.
This link may be of interest.
http://www.laptoprepair101.com/laptop/2006/05/10/buy-new-notebook-dvd-drive-tips/
Rich
Finally some help!! Regarding model details of laptop is: Sony Vaio VGN-CS16G. The DVDRW drive is: Optiarc dvdrw-7560S. Hopefully this helps, regards, Niv.
Message was edited by: rob619
Thanks for picking 3 out for me Rich, out of the 2 mentioned, not the 7560S which I currently have and can not find cheap online. Which would be most suitable out of the 2. Like last the longest and is the newest model, ive read some to be better then others?
Also will they definately work on my laptop model mentioned just to confirm?
Lastly actually replacing old one with the new one, will installation be hard, i.e. screws etc?
Cheers for the info
Hi Niv,
It is impossible for me to give a definitive answer to your questions. All I can say is that the two alternative drives should work but you need to address your questions to the supplier if you need guaranties.
Unfortunately I don’t have disassembly instructions for the VGN- CS series and I suggest that you start another thread for further help.
Rich
Thanks Rich, all everybody for the help! I managed to buy a second hand dvd-rw and replace it, was a nightmare with the many screws. Unfortunately relating to another topic, while under going this process a managed to scrach my cover 'chassis' and would like to replace this with a newer one. Looked online but can not find one...VGN-CS16G. If you could direct me, towards purchasing such item, would be great!
Hi rob619,
Suppliers of Sony Vaio parts a far and few between but for a second hand part have a look here:
Alternatively try eBay.
Rich
Hmmmm, dam there not cheap are they! For a piece of plastic dont know if its worth it? The laptop is semi-new and the scratches just big me, make it look worse. Obviously it doesnt effect the performance. The stuff on ebay is second hand, say that would have scratches on it anyways, which is more then likely. Dno what to do?
