IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 REPLIES 403
Blencogo
Hi donovani and welcome to Club Vaio.
Check in Device Manager and see if there is an error code given.
Start -> Right-click My Computer -> Properties -> Hardware -> Device Manager
Expand DVD/CD-ROM Drives.
Is there a yellow warning !
Double-click on the drive and look for the error code - ? If it is code 19, 31, 32, 39 or 41 then a small registry edit should sort the problem. Look back in this thread for the Registry Edit to remove the Upperfilters and the Lowerfilters.
:thinking:
Thalamus.
Champion
Hello, I've just bought a vaio computer (LM1) and I hav the exactly same problem with code 10, what do I do? Sorry for my write form, I'm french, I hav to translate.
Hi cathielle..
Press the windows key+R to open the Run box, then type devmgmt.msc and click ok..
Click Continue on the User Account Control window.
Double click dvd/cd-rom drives..
Right click on your drive and select uninstall
Restart your Vaio and allow the device to be re-installed again..
donovani
hi blencogo thanks for the welcoming
i jus tried wat you said but there is no DVD/CD-ROM drives to expand!!!
do you have any other suggestions? lol :tongue:
thanks for your help!
Thalamus.
Champion
Hi donovani,
do you have any unknown devices listed..
PintoMcGuinness
Hey,
Anyone have any ideas on this one?
Many thanks.
Apologies if this has already been asked - it's getting to be a long thread now!
I have a Sony Vaio VGN-C1S with Pioneer DVR-K16M DVD-RW (edit: with Windows XP)
The drive has been working fine, but now it seems unable to read any DVDs.
If I insert a DVD into the drive it finds it fine and knows a DVD has been inserted, but will not auto-start.
If you click on the drive through explorer it gives no errors, but lists no files at all and shows 0 bytes free, 0 bytes used.
It's seeing the disk, but not seeing any data on it.
I've uninstalled it, and I've updated the drivers (to a 14-11-2007 version).
I don't use it that much, so have no idea when it started to go wrong. That makes it hard to go back to previous setups.
Thanks in advance for any ideas.
donovani
hey thalamus!!
do you mean when i log in 2 my laptop?
where can i find such a list???
Thalamus.
Champion
hey thalamus!!
Have a look in Device Manager (see image below, the image below is from XP but Vista device manger will be very similar..).?
Thalamus.
Champion
Hi PintoMcGuinness.
Does the How To Enable/Disable Autorun (Windows XP) guide help.?
Click the following link to view the guide: How To Enable/Disable Autorun (Windows XP)
donovani
hey thalamus
am sorry for bugging you like this! and i appreciate your help!
when i expand that HID section all i get is 'sony notebookcontrol device'
i opened up the run box and typed devmgmt.msc like you said. all that happens is new device manager windows open up!
do you think i should consider system restore??? :thinking:
Thalamus.
Champion
hey thalamus
Do you have any other devices listed.?
