IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 REPLIES 403
Thalamus.
Champion
hello.. i dont have problem with the dvd of my new vaio VGN-AR51M but i cant play the blu-ray dvd that comes with it.all other normal dvd play allright but not blu-ray. can you help on that please do you know why? thank you..
Hi t-pilot
welcome to Club Vaio.. :slight_smile:
Have you checked for any Win DVD BD updates either at Sony VAIO Support or via the VAIO Update Utility: double click on the Vaio Update link in your system tray and follow the instructions.?
Acden
I have Sony VNG-Fz11SR
with Pioneer DVD-ROM. For 4 months it worked perfectly fine. But now I can't read any DVD (Cd - I can read).
What happends? What should I do?
How can I clean the laser's head? Can I use usual cleaning wipes for monitor?
I can read CD's! But no DVD (tried different)!
What should I do without contacting service?
joseph81o
Hi folks,
I own a VAIO VGN-FE21H.
It looks like the SONY DVD RW DW-G520A it came with has after intensive use over the past 14 months finally packed it in.
Personally, I don't believe I'm facing a driver or software related issue, because I'm working in a dual boot invironment (WinXP MCE & Win2003 on a second partition), and the disc player now refuses to work with neither.
Device Manager believes that the device is working properly, but that is just the typical windows nonsense one has come to expect.
The fact is that after inserting a disc the tray LED flashes three times, accompanied by three audible mechanical attempts to start or read the disc, but that's as far as it will go.
The thing is, I can take any desktop apart and put it back together with my eyes shut, but since this is my first notebook I want to make sure I'm not throwing money away by purchasing an overpriced SONY replacement, that is only going to last another 12 to 18 months again.
So the question I'm facing now is, do I have to purchase a replacement of SONY to make sure it'll fit this particular VAIO model (VGN-FE21H),
or can get a burner from a another source and can it be made (adjusted) to fit.
Any advice would be most welcome & appreciated.
Thanks.
msar2020
Can anyone recommend the best blank DVD's to use with a Sony DW-U54A. I can burn CD's (Mediastar CD-R-80), but cannot seem to find the right kind of blank DVD's to use (DVD-R?, DVD+R, DVD-RW? DVD+RW)?
Any suggestions. I tried Mediastar DVD-R, but all the DVD burner seems to do is to burn circles onto these discs and then say there is a "Cache synchronisation error". Happens in both Windows and Linux.
joseph81o
Hi folks,
Thanks.
I'm sure you'll all be happy to know that I sorted my own problem... again.
Got a replacement drive of ebay for £28.
Adjusted the brackets, fitted my own caddy and with that I saved myself a sack full of money.
Sony wanted me to send the whole unit (notebook) to them.
Selling me a replacement drive was of course out of the question.
Yeah right... are we all stupid or what?
Thank you so very much for your advice & support.
Ps. Btw., the drive is not hot-swappable, so lets be careful out there, ok.
trog
Hi, I have owned a VGN-A217S for 3 years now, have replaced the CD/DVD hardware twice and have never been able to do more than watch films (sometimes) through the DVD drive, when the machine can be bothered to find it. It has only ever recorded 2 things onto DVD-R, and forget DVD-RW.And I have tried every disc on the market, and what kind of an answer is this. This is a Sony for goodness sake, we expect more.
My final conclusion after trying many attempts at resolving the issue is that this aspect of the system is basically rubbish. After spending nearly £2,000 on this machine I have not rushed to this conclusion easily and resent having had to reach it, but hey, life is short. My advice is to invest in a cheaper, generic system for DVD work, it just isn't worth the hassle.
Just to say that I love Sony's stuff, every bit of decent electronics I own is made by them but they do make some very stupid and short sighted decisions, like putting a rubbish DVD package in a fantastic laptop AND LETTING MINIDISC DIE! Not sure I'll ever forgive them for this. At least Blueray is here to stay (isn't it?)
Sorry for the rant.
christoefour
Hi there. First off, I want to thank all the smart guys in this thread helping everyone out.
Now then. The problem I'm having seems to be related to similar issues spread over the last few pages of this thread.
My disc drive won't recognise blu-ray anymore. there are no error messages, the drivers are all up to date, and when I insert a BR Movie DVD, I can even hear it being read. However, there isn't any auto-play and none of the DVD software I've used (WinDVD, PowerDVD) can recognise a disc. I can't explore the contents of the disc and double clicking just causes a loading icon on my cursor (and then nothing).
Furthermore, if I restart my computer with the disc still in drive, the system will hang as if it is stuck reading the contents. I've got a blu-ray player that essentially treats blu-ray movies as blank discs. Every other type of movie/data medium works fine.
My drive is a Matshita BD-MLT UJ-210S ATA
I'm using a VGN-AR31S
Vista OS
Any help at all would be extremely appreciated. I AM DESPERATE :smileycry:. Thank you.
a4dil
I have sony n21s notebook which i have had for 9 months.
over the last few days i have had problems with my dvd drive.
each times i enter a disc the time taken to load the disc is longer and the drive makes more noises than before.
i used to nero7 to burn avi data discs successfully, however the data verification fails. i never use to have this problem before.
ive tried nero 8 and the burn process is successful but data verfication fails.
when i use the verbatim dvd disc to play in my sony hxd870 dvd player which can play divx data discs, the player rejects it and gives a message of inreadable disc.
i also used windows explorer to burn to disc which was successful. then tried it on the dvd player which rejected it again.
jonmerc
hi i have a sony viao notebook, the cd/dvd is not working (56a ) i have a freecom dvd /cd on the desktop but it will not play the recovery disc that i have for the viao, does it need to be the default player if so how do i do this any help would be appreciated regards john
Musicman
Hi, My DVD-RW drive, a DW-U54A is playing up, as it will not recognise DVD+R discs that are 16X speed. I read on some memorex discs, that the Firmware requires updating, is this true? If so how do I go about it, as it is becoming more difficult to find slower disks.
