Screen stays black during phonecalls
Kw2
I am not able to hang up while the phonecalls is active. screen stays black and on/off button does not work as a cancel.
1 ACCEPTED SOLUTION
Jonas
Master
You're welcome!
If have not tried to clean the adhesive side of a screen protector before, so I don't have any tricks up my sleeve, luckily @Viridis is an expert! Slightly_smiling_Face
Please follow his recommendation and see if you are able to remove these dust-dots!
I wish you the best of luck and have a great day! Slightly_smiling_Face
5 REPLIES 5
Jonas
Master
Hi @Kw2, I'm sorry to hear about that. Slightly_frowning_Face
There is a proximity sensor placed at the top part of your screen (just to the right of the Sony logo), which will turn the display off when you are in a call and when you take the phone away from your ear the display should turn on again.
If this sensor is covered by a screen protector or if there is any dirt/moisture on the sensor, the phone will think that the phone call is still active and the display will not turn on before the counterpart has ended the call.
Try cleaning the area of the screen where the sensor is placed with a dry cloth or remove any screen protector on your phone and either make a call and see if you experience the same behaviour or you can perform the inbuilt test in the phone for this sensor.
The test is found in Settings > About phone > Diagnostics > Test > Proximity sensor.
Let me know if that helps! Slightly_smiling_Face
Kw2
Thanks, it helped, but now I got some dust-dots stuck under my screenprotector on other parts of the screen. Do you have a trick to clean the adhesive side of the screenprotector...?
Lord_viridis
Sellotape, it sticks to the dust, but not the silicone adhesive on protectors
Jonas
Master
You're welcome!
Kw2
Thank you!
