Xperia X Performance won't start
Keist
When my Twitter app on my phone crashed I decided to restart it. When I powered it up and put in my password to start up the thing, and the Xperia logo appeared, it froze and then crashed. It then restarted, and the same thing happened over and over again and it still won't work. I tried removing my SD and sim card, as people had suggested, but nothing was different. I also tried holding the volume and power button for a while but it didn't work. What to do?
1 ACCEPTED SOLUTION
ChloeS
Contributor
Hi @Keist,
Welcome to the community!
Sorry to hear about that Slightly_frowning_Face with what you have already tried I would suggest trying a software repair using Xperia Companion.
If you are still having issues after the software repair you would need to contact your Local support to arrange an assessment and repair.
Good luck Slightly_smiling_Face
6 REPLIES 6
ChloeS
Contributor
Hi @Keist,
Bekim81
I'm having trouble with the touchscreen,the screen stays black I did the companion software repair and it's even worse. I bought it 2 weeks ago from the first day I had the same issue. Please help it's definitely defect from manufacturer
Uliwooly
@Bekim81
does the phone has any protective case, film and/or glass?
Bekim81
The phone is new 2 weeks old no cover no nothing just freezing I can hear the phone is working in background but the screen is black
Uliwooly
@Bekim81
I've seen that before when users have dropped their phone, you will have to contact either the store or your Local support
Norm615
So manufacturer defect. I would think it should be covered under warranty as such failure is indicative of poor quality or design.
