Battery suddenly drops from 60% to zero
Curlymike
The battery suddenly drops from 60% to zero. Has been doing this for a month. Seems to recharge very very quickly afterwards. Indicates software or power management issue. Help... Can't live with 40%...
Tags (1)
15 REPLIES 15
Datts
i received an update of 341mb just 2days before, but right after update i started encountering the problem of battery like whenever the battery reaches 50% or 45% the indicator suddenly shows battery at 0% and phone shutting down. i dont knw how is it but i can certainly tell it happened after new update. please let me knw the solutuion asap
Curlymike
I have the same problem, but from 60%
IPaltus1
Having the same problem.
The battery drops form 84% down to 0%.
When switched on again it could be 1%, 40% or 60% (more or less)
I faced the problem when upgraded to 5.0.2
Everything was Ok with 4.4.4
Now the problem persists with 5.1.1
Rolled back to 4.4.4. - no problem.
Even if soemthing's wrong with the battery why Android 5 behaves in this way?
xavinux
Enthusiast
Hi @Curlymike @IPaltus
Seems that Google has taken on some measures on fast battery drain after Lollipop update, you can check this link:
https://code.google.com/p/android/issues/detail?id=165558
Post number 1023 is an answer from google about the reported bug.
I'm at disposal for any question.
Best Regards,
xavinux
Enthusiast
Kulveer_Singh
Contributor
Remove, if u install any battery saving app. I am also facing that problem after enable hibernate feature of Clean Master. After remove battery drain problem solved.
GeoffH
Enthusiast
I have to agree with all of the above, since 4.4.4 update my phone has been experiencing all of the symptoms above and more, there is something very wrong with how - either sony has adopted battery handling in LP or Google code is at fault, either way there is something not right here and I reported this months ago
as an example, I just rebooted my phone with 70% battery and it restarted with 2% and shut down
something is very wrong here
maybe they want you to buy a new phone
frogie4life84
That means we have to wait for another update. I mean time we have to wait and wait again. Drooling_Face
Thanks for posting the message.
JohnYeldham
One of the updates - not sure which - permanently damages the phone battery. It happened on my z1.
No software update will help. You have to replace the battery. If you under warranty send it back to Sony. If not (like me) be prepared for plenty of extra costs, and a phone that is no longer waterproof.
