How many times have you used the PUK code?Are the SIM cards activated? Or do they need to be activated on first connect?
good to hear. Try and find a sim card adapter if the cards aren't the exact size
Btw, the PUK code also works like a device security PIN... If you get it wrong too many times you need to call the carrier to issue a new one if you lock it out
Is the SIM a current SIM?
@NeoBeum wrote:Is the SIM a current SIM?
Yes, brand new. This is the third sim that ive tried. It works in Samsung and Nikia.
