IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 REPLIES 403
porshe944
bonjour a tous
voila mon souci g un SONY PCG-GRT 916V et il ne veux pas lire de dvd donc impossible de reformater avec le DVD d'origine fournie avec......
voila je pensais qu'il etait possible de reinstaller tout le systeme en copiant le CD sur une clef USB mais il ne reboot pas dessus
si quelqu"un a une solution a mon probleme je suis tout ouïe
merci d'avance
(DVD RW DW-U54A)
mike_stuart
I have had numerous problems with my CD/DVD drive on my Vaio VGN-FE31Z, but I have recently managed to get it half sorted using tips on here. Now I can read normal CDs and DVDs, but I cannot write to discs. I've tried different CD-RWs but no success using Windows Media Player; it tells me to connect a burner and restart the player, and i cannot access the CD-RW through My Computer either; it just tells me to insert a disc into f:.
Any ideas please?
Many thanks,
Mike.
Thalamus.
Champion
Hi Mike,
Are you able to burn CD-RW's when using Roxio DigitalMedia SE 7...?
mike_stuart
Hi Mike,
It appears i've uninstalled Roxio, but SonicStage does successfully burn music to a CD... do you know how to make Windows Media Player do it though, since I spent hours today making a playlist to burn! :slight_frown:
EDIT: It is a Matshita UJ-850S DVD-RW drive, which is fully compatible according to the Microsoft Website. Haven't found anything useful on the WMP FAQ/Help.
reddzer
i have a vaio VGN-SZ4VWN/X
i'm getting the following error with my DVD/CD DRIVE. This device cannot start. (Code 10)
any ideas?
Blencogo
Hi reddzer.
This is the 'catch all' error code produced by the operating system when it hasn't a clue what the problem is and the drive just does not work.
The most common cause is because the IDE cable to the drive has become disconnected but it could be any hardware fault. As it is almost certainly hardware - just check that the read head in the drive is not sticking. Make sure it slides for the full range of its travel.
Your drive will have to be looked at/replaced so I would phone Sony Vaio-Link Support for guidance. They will probably ask you to carry our a full System Recovery before accepting the Vaio for inspection/repair - so get your data backed up!!!
Sorry it's not good news!
:slight_frown:
chyke99
:wink:
chyke99
I have an error sign on my DVD/CD drive on the Matshita DVD-Ram UJ-8505 ATA device. Can you offer me help
Blencogo
Hi chyke99,
Please double-click on the device in Device Manager and tell us what the Error Message is?
:thinking:
Musicman
Hi, I have a problem, in that my DVD-RW drive, a DW-U54A is playing up.
It appears that it can read any CD's, but is having problem readings DVD's. It will nor read any bought DVD's, along with any DVD's that were produced on the drive before the start of this year, (though I have been unable to find two disks I produced at the end of the year to verify this) though these disks were produced early last year. However a backup disk I created on a RW disk in March, can be read. All the disks that failed to read can be read on another PC. I did place a suspect DVD in the drive in February, that was scratched, but the drive did appear to be working after that.
As I cannot read ant DVD's I cannot perform a recovery!!!
Has anyone any ideas?
