How it will be corrupted all of sudden after a software update....i have decided to format and check...will update you once it completed.
But i have a suspect that the issue occured after some mobile applications such as VLC,MX Player are opened and i saw the videos and heard songs. Because exactly the same file which i opened in mobile app..is not showing in the card when i view it from PC.
After 33.2.B.3.74 update SD card was getting ejected then i did factory reset then its not getting ejected but
im not able to move apps from internal memory to SD card error message in NOT ENOUGH MEMORY SPACE..
i have 32GB memory card its just not possible
Model Number is F3116
Sony please look into the issue and fix the issue
I'm facing the same problem too. I did all of these (factory reset, format my sd card and used software repair via xperia companion) and it worked fine until i move my app to sd card. After move first app, it is fine. The sd card will be automatically ejected at the second and I cant do anything with it until restarting my phone. It also happen when I tried to format sd card after moving app to it.
After this update I have the problem with wifi authentication too and another problem is when I press power button to open the lock screen, there is a quick notification pop up about sd card at the lock screen which I can't read it cause it gone too soon!!
Plese help SONY, I lost my data but nothing of these works. I'm not gonna use my phone for a while until I get an update because I tired of configuring my phone and lost my data for nothing ;(;(;(
