SD Card automatically ejecting after update
Kedarmane
Today 22 Sep, my xperia XA got updated, after that my sd card automatically gets ejected. My new build number is 33.2.B.3.74.
Tags (1)
53 REPLIES 53
AnshXA
Its probably corrupt, the sd card.
Rajeswaran
How it will be corrupted all of sudden after a software update....i have decided to format and check...will update you once it completed.
But i have a suspect that the issue occured after some mobile applications such as VLC,MX Player are opened and i saw the videos and heard songs. Because  exactly the same file which i opened in mobile app..is not showing in the card when i view it from PC.
Kedarmane
Sony plz help. As we are not able to use our data as it is stored in sd card..plz update and solve the issue
sanket_rane
After 33.2.B.3.74 update SD card was getting ejected then i did factory reset then its not getting ejected but
im not able to move apps from internal memory to SD card error message in NOT ENOUGH MEMORY SPACE..
i  have 32GB memory card its just not possible
Model Number is F3116
Sony please look into the issue and fix the issue
Ayushtg649
After the latest Ota update of my Xperia xa on 23rd of September I'm facing several problems like
Automatically unmounting of sd card. A notification often pops up saying sd ejecting sd card don't remove. Also my phone restarts on its on and keeps restarting till I press and hold power and volume up button at least for 8 secs. Please look into the matter and help accordingly.
Roadrunny76
Enthusiast
Good to know for others who will update: take SD card out before update. Anybody did this and still got problems?
qairul
Im also have the same problem.. Phew~
esergen
Same issue, with factory reset it works now..
babyju5t
I'm facing the same problem too. I did all of these (factory reset, format my sd card and used software repair via xperia companion) and it worked fine until i move my app to sd card. After move first app, it is fine. The sd card will be automatically ejected at the second and I cant do anything with it until restarting my phone. It also happen when I tried to format sd card after moving app to it.
After this update I have the problem with wifi authentication too and another problem is when I press power button to open the lock screen, there is a quick notification pop up about sd card at the lock screen which I can't read it cause it gone too soon!!
Plese help SONY, I lost my data but nothing of these works. I'm not gonna use my phone for a while until I get an update because I tired of configuring my phone and lost my data for nothing ;(;(;(
1adrian1
Contributor
They should pull the update if it has problems, nothing else has been released since.
